Mast and rigging setup
Regatta
Inlägg av Regatta »
Hello,
I just rise my mast in my Marieholm 26 with a professional rigger. My question due the fact that folkboat in italy are probably 6/7 total there are no experience or instruction wich is the best seup for mast, rank bend etc etc...
Thanks to anybody could help me and give information or tips. I've a selden mast with original neil pride sails.
Thanks in advance
Gabriele
http://www.marieholm26.org
Re: Mast and rigging setup
On our website www.ifboat.com you will find a trim guide in English for the IF-boat, which will do very well for an M26:
http://www.ifboat.com/trimguider/north/ ... tg_eng.pdf
Regatta
Inlägg av Regatta »
maja skrev:On our website http://www.ifboat.com you will find a trim guide in English for the IF-boat, which will do very well for an M26:
Thanks Maja , always helpful!!!
Gab
stonjohn4
Inlägg av stonjohn4 »
Hey Sailors, I am adding a spinnaker to my rig and need to know what height on the mast above the lower spar band the turning block for the topping lift is secured . It doesn't appear to state the measurement in the class rules. Thanks, otter.
ccnp cisco dumps ccnp cisco dumps
ccnp course dumps ccnp course dumps
a+ comptia dumps a+ comptia dumps
free braindump exams latest free braindump exams latest
If you mean the block (or sheave) for the spinnaker boom lift, the height is free according to the class rules. As a standard for older spars (before 1972), there is a fitting for a turning (swirling) block at spreader height, and the entire lift rope is meant to be running outside the spar. On rigs after 1973, there is a sheave integrated in the mast spar approximately at the same position, and the hoisting end of the rope is running inside the spar and comes out of the spar near the mast step.
