My IF does not have a cabin/cockpit table. It must have got lost in the past as the fittings are still in the floor!
I've attached a couple of photos taken from Twitter which shows what I assume is the original table design?
Does anyone know if there are dimensions / drawings of the table available somewhere? (Medvind?)
Are the can the screw fittings still be purchased anywhere?
Thanks All,
James
Table design and fittings?
Pancho
- Segelnummer: 3344
- Båtnamn: Pancho
- Has thanked: 2 times
- Been thanked: 2 times
- IMG_1620.jpg (96.16 KiB) Visad 4365 gånger
- IMG_1619.jpg (100.74 KiB) Visad 4365 gånger
James Baker
IFe "Pancho" SUI 3344
James Baker
Re: Table design and fittings?
What you display is the original design of the table for the IF.
If you are lucky, you may buy one from somebody who doesn't use it anymore. Many IF-boat owners have swiched to the "Laguna" table, which may be bought new in the marine equipment stores.
If you buy used equipment, please be shure that you get all bits and peices, i.e. table supports and legs.
Pancho
- Segelnummer: 3344
- Båtnamn: Pancho
Thanks - it sounds like the fittings and legs aren’t available to purchase new?
James Baker
James Baker
That's correct .
Maybe Second Hand or retrofit manufacture.
