Sökningen fann 20 träffar
- 08 maj 2023 00:26
- Kategori: Allmänt
- Tråd: IF History - SUI 3344
- Svar: 0
- Visningar: 2539
Hi, Is there any way of tracing my IF's history? Sail No SUI 3344 but now in the UK and named 'Pancho'. I bought her here in the UK in 2021 from Mr Chris Calvert (boat name was Elpenor), and before that she was owned by Mr Andrew Molloy in Plymouth, who bought her from Mr David Lines in Jun 18. I ...
- 05 apr 2023 16:09
- Kategori: Skrov
- Tråd: Leaking forehatch
- Svar: 1
- Visningar: 2226
Leaking forehatch
Any good ideas on how to stop the forehatch leaking? I replaced the seal at the start of last season but even with the screw fitting tightened I can see daylight!
I’m wondering whether I need a screw fitting in the two forward corners rather than just one in the middle…?
- 28 dec 2022 22:27
- Kategori: Beslag
- Tråd: Aluminium Grab Rails
- Svar: 3
- Visningar: 4178
Re: Aluminium Grab Rails
Thanks Maya - I will try to find some.
- 21 dec 2022 14:09
- Kategori: Beslag
- Tråd: Table design and fittings?
- Svar: 3
- Visningar: 3214
Re: Table design and fittings?
Thanks - it sounds like the fittings and legs aren’t available to purchase new?
- 19 dec 2022 17:47
- Kategori: Beslag
- Svar: 3
- Visningar: 3214
My IF does not have a cabin/cockpit table. It must have got lost in the past as the fittings are still in the floor! I've attached a couple of photos taken from Twitter which shows what I assume is the original table design? Does anyone know if there are dimensions / drawings of the table available ...
- 19 dec 2022 16:37
- Kategori: Beslag
- Svar: 3
- Visningar: 4178
Hello everyone. Unfortunately one of the aluminium grab rails on my coach roof has been damaged and I need to replace it. The photo is before the damage!
Are the original parts anodised or just plain aluminium? I want to make sure I get something that matches.
Thanks and Happy Christmas to all.
- 02 nov 2022 00:18
- Kategori: Common
- Tråd: Cockpit floor
- Svar: 0
- Visningar: 4062
Cockpit floor
Hi. My IF has 2 removable panels on the cockpit floor to access the engine.
Are these original, or have these been added later?
Does anyone have any advice on how to make the hatches properly water tight? The seals on mine aren’t very good and leak.
Thanks everyone,
James
Thanks everyone,
James
- 08 aug 2022 18:13
- Kategori: Common
- Tråd: What size / type of hatch seal do I need?
- Svar: 3
- Visningar: 6253
Re: What size / type of hatch seal do I need?
Thanks all - I’ve ordered 3 metres of 16mm EDPM foam. Slightly smaller than the old one which was a bit too big.
- 07 aug 2022 22:42
- Kategori: Common
- Svar: 3
- Visningar: 6253
Hello everyone,
I have just removed the old seal on my forehatch and need to replace it.
What size / type / shape of seal is best to use? I have removed a round seal but I'm not sure if that is correct.
Thanks,
James
Thanks,
James
- 07 maj 2022 08:19
- Kategori: Segel
- Tråd: Spinnaker dimensions
- Svar: 1
- Visningar: 4438
Hi All, I am looking at buying a second hand spinnaker for cruising and there are some advertised locally. Does anyone know the approximate luff and foot dimensions of the one design spinnaker. I know the area is 36.3 m2 but those advertised simply have luff and foot measurements listed, so it would ...
- 25 apr 2022 20:45
- Kategori: Rigg
- Tråd: Shroud attachment fitting
- Svar: 2
- Visningar: 3749
Hi All. I think I have lost one of the 2 deck fittings for my IF cap shroud. Does anyone sell them? I have replaced the fittings for my lower shrouds with the 4 bolt version from seacamper, but I don't think they sell the fitting for the long cap shrouds. Any help or suggestions welcome - thanks ...
- 02 feb 2022 00:31
- Kategori: Common
- Tråd: Steel bow fitting?
- Svar: 4
- Visningar: 7177
Re: Steel bow fitting?
Thank you everyone. Reassuring to know this fitting is also found in other boats too. I plan to dry it out properly and then fill with some Epoxy before replacing the bow fitting. I also managed to clean out my hull / deck joint last weekend and replace the sealant with Bostik MSR CA. Hopefully that ...
- 23 jan 2022 23:48
- Kategori: Common
- Svar: 4
- Visningar: 7177
Steel bow fitting?
Hi,
I removed the stainless steel fitting from
my bow and there was oxidation coming from a steel fitting underneath.
Any idea what it is, and whether I should remove it? I have drilled around it, but I haven’t been able to get it out so far.
Thanks,
James
Thanks,
James
- 17 jan 2022 22:05
- Kategori: Common
- Tråd: Is this forum section needed?
- Svar: 6
- Visningar: 8389
Re: Is this forum section needed?
Hello All, When I was looking for an IF boat to buy I found the English section a really helpful place to start. Now I have bought one, I find the Swedish section most useful as the detail in the technical sections is really helpful - with the help of Google translate. Yes Google struggles with ...
- 15 jan 2022 21:23
- Kategori: Common
- Tråd: Hull - Deck join
- Svar: 8
- Visningar: 9364
Re: Hull - Deck join
Thanks All,
Going to use the Bostic sealant as suggested.
Lots of leaks all around the deck fittings too so I’m removing and re-sealing all of those, and the windows too.
