Sökningen fann 2 träffar
- 04 dec 2011 16:46
- Kategori: Common
- Tråd: Difference between IF and Marieholm 26? Exact weight?
- Svar: 14
- Visningar: 47662
Re: Difference between IF and Marieholm 26? Exact weight?
Here's some information I've got from Göran Helmer (former salesmanager of Marieholmsbruk) ; The keel ballast for the IF is 1.250 kg, i.e. 58%. For the IF E with inboard engine the keel ballast is cut off at the end of the ballast. Believe some 150 kgs were cut off in order to compensate for the ...
- 18 feb 2011 17:40
- Kategori: Common
- Tråd: diameter cap shrouds
- Svar: 1
- Visningar: 8763
As far as we know, here in Holland some or maybe all IF's were originally delivered with cap shrouds of 6 mm.
In the class rules a size of 5 mm is mentioned for cap shrouds. I suppose this is the minimum, but how long does it last ?
Is 5mm safe enough at the long term ?
