Sökningen fann 22 träffar
IF covers
Hi, I am beginning to update our IF and would like a full cover that I can use while moored in our slip. Are there any manufacturers who already make covers for the IF? I've found one in the UK for the old style Folkboat but not the IT. I'm located in Virginia on the east coast of the US but will ...
Main sail
Hi, I'm looking for a new main sail. My IF has an old main from Northsail but I'm not too pleased with the cut. I have it used so it may have stretched and of course it is well worn. However, good quality construction. What supplier do you recommend? Mainly cruising type sailing. thanks. iamsville
- 07 aug 2011 17:33
- Kategori: Skrov
- Tråd: Läckande IF-E
- Svar: 16
- Visningar: 30261
Re: Läckande IF-E
Hi, check the Gudgeons, the bolts that hold your rudder to the keel. I found mine leaking when one had come loose.
iamsville.
iamsville.
Re: main sail
thanks all!
main sail
Hi all, I'm searching for a new or good condition main sail for our Marieholm folkboat. Any recommendations as to where one may be obtained?
thanks,
iamsville
thanks,
iamsville
- 13 okt 2010 01:54
- Kategori: Roder
- Tråd: Spricka i roder
- Svar: 3
- Visningar: 10879
Re: Spricka i roder
The outside of the rudder Seams very rough at the water level. Would suggest sometime physical damage to the rudder Perhaps from Being in Water During freeze? Heavy Barnacles? Seems previous damage at area near crack But now Covered by the paint. How long have you owned your IF? As Maia says, note ...
- 09 okt 2010 14:23
- Kategori: Skrov
- Tråd: Läckage i akterpiken
- Svar: 9
- Visningar: 19809
Re: Läckage i akterpiken
Hi, i would recommend checking all the deck fittings in the area. I have had these leak overtime. Good luck!
- 26 sep 2010 13:58
- Kategori: Common
- Tråd: Happy New Owner of IF 2595
- Svar: 7
- Visningar: 20988
Re: Happy New Owner of IF 2595
Thanks Maja, I may try removing my engine and storing it in the locker when under sail. I currently have a 6 hp with the starter cord through the cockpit wall. I have a 4 hp also and wouldn't have to do this to start the engine. It has its own gas tank on the top as well making it all self contained ...
- 23 sep 2010 02:01
- Kategori: Common
- Svar: 7
- Visningar: 20988
Hi , We've HAD OUR IF for about nine months and Keep It On a lake in Roanoke , VA . We Have a 6hp outboard That we keep in the motor locker. We sometime lose speed on a starboard tack and occasionally pick up water sometime in the locker . This drains though. Port tacks are fine . Maintenance isn't ...
- 07 aug 2010 15:58
- Kategori: Beslag
- Tråd: Bomliksträckare och roderfråga
- Svar: 7
- Visningar: 15822
Re: Bomliksträckare och roderfråga
Believe your tiller is cracked in the round part. Attached Have a picture from my spare. Hope this helps .
- 03 jul 2010 22:57
- Kategori: Skrov
- Tråd: Spricka i förstäven
- Svar: 7
- Visningar: 17540
Re: Spricka i förstäven
I would check the tension or adjustments of your standing rigging. Also, how much tension is on the forestay when you have your IF moored. I do not have this cracking on our IF but always leaving slack in the backstay when moored.
Good luck
Good luck
Re: läckage
Hi,
I had leakage from the bow pulpit and from the lifeline stanchions. Rebedded and haven't had a leak since then.
- 12 dec 2009 02:42
- Kategori: Common
- Tråd: Marieholm plaque
- Svar: 4
- Visningar: 15285
Re: Marieholm plaque
many thanks. Will post a photo when upgrades are completed.
- 04 nov 2009 23:51
- Kategori: Common
- Svar: 4
- Visningar: 15285
Hi Janne,
Many thanks. The plaque is very thin aluminum and grey. The letters also have no color. I've added a picture and circled the plaque. The letters soon will be black.
Regards
iamsville
Regards
iamsville
- 02 nov 2009 01:44
- Kategori: Common
- Svar: 4
- Visningar: 15285
Marieholm plaque
My 1976 Marieholm has an aluminum plaque (name plate) on each side of the cockpit. There are no colors but work Marieholm is clear. Does anyone know what the original colors were for this plaque? I would like to return it to original condition.
thanks
iamsville
thanks
iamsville
