Sökningen fann 12 träffar
av OGB
29 apr 2019 12:34
Kategori: Forum
Tråd: Vår webbsida lider av pågående serverprobem på webhotellet
Svar: 2
Visningar: 10352
Re: Vår webbsida lider av pågående serverprobem på webhotellet
We also have difficulties with our new website www.ifboat.uk which we registered with 123Reg . We will probably move it to another host. We have posted it in honour of the 25th anniversary of the UK IF-Boat Association, please let me know if you have any suggestions or find any errors.
av OGB
29 apr 2019 12:00
Kategori: Kappsegling
Tråd: Rules
Svar: 1
Visningar: 8932
Rules
Please can you translate into English "Förliksrep eller förlikstravare och underliksrep ska vara i rundhultens likrännor. " Google translated this as (ii) 'Conciliation rape or conciliator and subordinate rope should be in the cave' luff grooves. [My Slightly less bizarre translation- Settlement [l ...
av OGB
05 aug 2013 11:17
Kategori: Common
Tråd: IF Boat engine location plans
Svar: 7
Visningar: 22848
Re: IF Boat engine location plans
As far as I am informed, it is not possible to buy a new 2-stroke petrol engine of the "old normal" design (carbourator and no pistons) any more in Scandinavia due to emmission rules. Maybe this Dolphin Series 2 two stroke engine is of a more modern design with no such emmission problems. Maja, see ...
av OGB
05 aug 2013 11:00
Kategori: Common
Tråd: IF-E New Engine
Svar: 3
Visningar: 14279
Re: IF-E New Engine
Only a small comment to the required power: I think that more than 10 hp is not reasonable. According to my opinion 5 hp is enough. I used 5 hp outboard engine. Later I changed to 8 hp outboard, but I run it at halve the power with the advantage that it is not so noisy. You can look at this engine ...
av OGB
01 jul 2012 14:23
Kategori: Common
Tråd: Difference between IF and Marieholm 26? Exact weight?
Svar: 14
Visningar: 46309
Re: Difference between IF and Marieholm 26? Exact weight?
Rather belated thanks for solving the problem!
av OGB
05 aug 2011 15:09
Kategori: Common
Tråd: Difference in weight between Inboard and Outboard IF boats
Svar: 3
Visningar: 13168
Re: Difference in weight between Inboard and Outboard IF boa
Many thanks Nils, I am going to do as you suggest . I am gathering some lead to melt down.
av OGB
25 jul 2011 19:25
Kategori: Common
Svar: 7
Visningar: 22848
I imagine you have decided where you will locate your engine but you may be interested in the installation of the neat little Dolphin Series 2 two stroke engine the video gives a good idea of the location see http://www.beautifulcottages.com/i/Engine.mp4 . You can see the tops of the engine mounts ...
av OGB
25 jul 2011 15:43
Kategori: Common
Svar: 14
Visningar: 46309
Yes the boat is down by the bow to the extent that the cockpit drains into the bilge rather than through the aft cockpit drains. Obviously the position is better with two heavy crew aboard.
av OGB
25 jul 2011 15:41
Kategori: Common
Svar: 3
Visningar: 13168
Posted by Thorbjørn, DEN 312 Are you sure that it is down by the bow? I mean, of course it is if you compare with your usual waterline but what if you compare with the drawing? You have perhaps already done this comparison .. My answer Yes the boat is down by the bow to the extent that the cockpit ...
av OGB
25 jul 2011 13:55
Kategori: Common
Svar: 3
Visningar: 13168
I am interested in the weight of my IF boat. Reg no 2630. What is the difference in overall weight of one fitted with an inboard engine and one without? I had a volvo MD1B probably fitted as original equipment in 1976 when boat was built by Marieholms Bruk. The basic information given is Model ...
av OGB
25 jul 2011 13:25
Kategori: Common
Svar: 14
Visningar: 46309
I also am interested in the weight of an IF boat. What is the difference in overall weight of one fitted with an inboard engine and one without? I had a volvo MD1B probably fitted as original equipment in 1976 when boat was built by Marieholms Bruk. The basic information given is Model Number LOA ...
av OGB
22 jul 2009 18:06
Kategori: Common
Tråd: Handicaps/Displacement
Svar: 0
Visningar: 6881
I am very interested to hear from anyone who is racing in a mixed fleet of standard Marieholm IF boats some with Outboard(OB) and others with Inboard (IB) engined boats (possibly also Marieholm 26's also IB). If so do you have a handicap system ? PY or equivalent ? What are the relative handicaps ...
