Svenska IF-båtförbundets forum • Hull numbers
Hull numbers
Postat: 19 sep 2013 20:15
av Plankit
Hi all, just recently found some marieholm placards in storage. Does anyone know where to look or where the hull number corresponds to year and make.
One of the plates have number 153. The other has 360-69. I'll try to send along some photos. Any help or direction would be great. Thanks.
Re: Hull numbers
Postat: 19 sep 2013 22:31
Plankit skrev: One of the plates have number 153.
The 153 is the initial Swedish sailnumber.
The 360-69 is the hull number (360) and the year of make (1969)
Re: Hull numbers
Postat: 20 sep 2013 05:03
av Plankit
Thanks again maja. The hull on this boat is gutted. Where are the plaques mounted usually? I'm under the impression this boat was 1974. Are there signs within the hull to tell what year it was built,maybe construction details?
Re: Hull numbers
Postat: 20 sep 2013 11:13
If built in Sweden in 1974, there should be just one plaque.
Boats with two plaques (earlier built than 1972) have those originally mounted on the main bulkhead (beneath the mast) on port side.
Boats with one plaque ( later built than 1972) have this originally mounted on the main bulkhead on starboard side.
Send me some detailed photos of rig and deck and I will have a try...
